LabVIEW Interface for Arduino Discussions
Generate a high frequency signal from Arduino
Hello everybody,
  I'm working on connecting the Arduino to ultrasonic speakers JSN-SR04T. I have 2 of those speakers and I am trying to make them "speak" to each other. One of them will act as a transmitter, which only sends out signal, while the other one act as a receiver that only receives the signal sent from this transmitter. I have already tested whether this would work by connecting the transmitter to a function generator and the receiver to an oscilloscope. There isn't any chipboard configuration in the connection. I simply connected the VCC of the function generator/oscilloscope to the VCC of the speaker, and GND connects to GND.
  Now I'm trying to replace the function generator and the oscilloscope by using LabView. I don't really have the funding for a DAQ, so I could only play with Arduino. I need to be able to modify the emitted signal to 40k Hz and use the "tone burst" function on a function generator. The tone burst function basically bursts a signal, making the signal to have high for a burst of time and stays low until the next high is triggered. I think the "tone burst" function can be done by changing the duty cycle of the wave to a very small number. But I don't know how to make the signal emit at 40k Hz.
  Thanks!
(6,026 Views)
this web pge <http://forum.arduino.cc/index.php?topic=172649.0> says  "
65535 Hz.  The parameter is an unsigned int."
hrh212
(5,534 Views)
Thanks for the info!
Do you know how to generate such signal?
(5,534 Views)
Simply use the tone function with a small duration.  Does this not work for you?
(5,534 Views)
