LabVIEW Interface for Arduino Discussions
HELP !! help needed =(
Anyone knows how do i transfer data from my arduino into labview?
( i want to show these results in labview instead of arduino )
and also how do i insert 3D image to labview ?
like a 3D image of this . So that im able to show the movement of it.
anyway, this is a sparkfun board serial 9DOF .
thank you 😃
(4,293 Views)
It looks like you are not already using the LIFA firmware so you would need to install that and then write custom functions to communicate with the sensors.  I'm not sure if there is a way currently set up to just read from the serial port and use that info but it might be possible.
The former is not all that easy because I don't believe there is currently functions developed for those sensors.  If you choose the latter then this section is not really relavent to your question.
(3,578 Views)
i will just program a VI to dump all that information via serial port to labview
CLAD, CTD
(3,578 Views)
utiliza lifa , o tambien puedes utilizar el puerto serie com.......
(3,578 Views)
