LabVIEW Interface for Arduino Discussions
Hi pls tell me
I just now know labview have one toolkit for Arduino,my doubt is, this toolkit is used to develop the coding which is going to run inside arduno microcontroller or intrerface with Arduino hardware with labview ? can u tell me?
Raj
(4,800 Views)
Ya, I have the same question. Is the VI running on the PC or on the Arduino? Hence, can I run the arduino independently of the PC.
(3,856 Views)
Hey,
Check out the FAQ (specifically number 7):
https://decibel.ni.com/content/docs/DOC-16024
At this point you cannot deploy code to the Arduino (run a VI on the arduino) you can only 'talk to' an arduino.  You can however communicate with the Arduino wirelessly via Bluetooth or Zigbee (Xbee) so that you don't have to be physically attached to a PC.
Let us know if you have any other questions.
-Sam
LIFA Developer
(3,856 Views)
thanks
Raj
(3,856 Views)
