LabVIEW Interface for Arduino Discussions
How can I send commands and receive ouputs from arduino using VISA
I am working on a project concerning Wireless Sensor Network using Xbees and Arduino, and the idea is to control when to read data, from which sensor, and then save each sensor's measured data into a specific file (or column in TDMS files) ..For now I want to control an arduino by sending a command and receiving a response using Labview. I'm new to this so bare with me please:
1- I have modified the arduino firmware (LABVIEWinterface.ino) that LIFA provided, to add two cases:
case 0xB8:
digitalWrite(13, HIGH);
Serial.write("hii");
break;
case 0xB9:
digitalWrite(13, LOW);
Serial.write("bye");
break;
2- I have made a simple labview code, but when i send B8, or it's equivalent in decimal nothing works and i get a timeout error.
Maybe, there is another proper way of sending commands and receiving data from labview ?
Appreciate your help
(4,136 Views)
When using LIFA firmware on the Arduino, you must also use LIFA in LabVIEW.  However, LIFA has been deprecated for quite a while now and therefore, you should upgrade to the LIFA replacement called LINX.  Similar to LIFA, you will be able to add your own custom commands to the firmware.
(3,689 Views)
