LabVIEW Interface for Arduino Discussions
How to merge processing code for HMC5583L and MMA7361C
I am unable to attach files on this chatbox i have no idea why. Ill try to get a link from my teacher as he passed down the file to me.
Message 21 of 32
(2,043 Views)
You have to click "Use advanced editor" to be able to attach files.
Message 22 of 32
(2,043 Views)
Oh thanks!
Message 23 of 32
(2,043 Views)
Hey Nathan i edited the HMC5883L file by changing the send and receive to write and read and the errors dont appear any more. Ill attached the edited file, help me have a look!
Message 24 of 32
(2,043 Views)
Here is an example of talking to the HMC5583L based on the files you posted.  Let me know if it works.
Message 25 of 32
(2,043 Views)
there wasnt a constant data display. My labview shows correct vales at right angles but isnt showing stable results inbetween, but i think i can fix that by adjusting the sample freq for the sensors.
1 more thing, i have to display my labview data on a arlcd which has an arduino board attached to it. I am unable to find any exaples to do so. Is that even possible?
Message 26 of 32
(2,043 Views)
Did the code that I posted work?
Acquisition rate shouldn't affect the results of a magnetometer (it's not a dynamic thing if you are using it as a compass).  However, if there is any magnets or magnetic fields near your sensor, it can affect the measurements (relative to the Earth's magnetic field).
I don't know what that is.  What is it?  How does it communicate?  Can you provide a link to it and it's datasheet?
Message 27 of 32
(2,043 Views)
The code you posted was able to run but the data being displayed was not stable, it kept fluctuating rapidly.
Im using an accelerometer and a magnetometer sensors working together to produce magnetic direction and pitch and roll data displayed on labview, and for that i need a acquisation rate which will produce stable results.
Oh right haha sorry ill attach all its relavent specifications.
http://store.earthlcd.com/LCD-Products?search=arlcd
Message 28 of 32
(2,043 Views)
You'll need to use some sort of filter but you need to consider that the
speed of acquisition via LIFA will be relatively slow and will be affected
by everything else running on your computer.
I'll have to look at the LCD later.
Message 29 of 32
(2,043 Views)
Alright alright. Sure please do, thank you!
Message 30 of 32
(2,043 Views)
