LabVIEW Interface for Arduino Discussions
How to stop and send a message ?
I want to stop the program and send a message if the "fwd amp" or "rev amp" indicators show "2.3"~ or more, any suggestions ?
(4,893 Views)
This is how to stop the loop if either of the voltages is greater than 2.3V and then show a message.
It will only show the message if the loop stopped by one of the two voltages and not when you hit the stop button.
EDIT:  I noticed that I used the wrong voltage for the conditionals but you can obviously change that to your desired value.
(4,582 Views)
thanks, i will test it in some hours, ill post the results.
edit:
It worked, also, i searched a little bit and I did it with a state structure "machine"
if the amps are bigger than the set point, I stop the motor from working and I display a message asking for a password to continue.
herespart of the VI
thankshttp://i.imgur.com/LdpUZ5K.png
(4,582 Views)
I replied to wrong message. Apologies.
(1,820 Views)
(1,819 Views)
