LabVIEW Interface for Arduino Discussions
How to use the analog inputs of Arduino ONE in Digital mode?
Help me, please.
In the Arduino IDE I can use the analog inputs in digital mode, and I have 19 Digital I/O...
Now, I want know how to use this option in LabVIEW.
Best Regards!!
(3,897 Views)
You would need to add that functionality to LIFA (firmware and LabVIEW).  I'm quite sure I remember some other posts about this but I can't remember if anyone created these functions but you could try and find those posts.
(3,158 Views)
Ok, I found a solution for my problem, in the LIFA directory exists a folder called Utility, in which exists a VI "Check for Pin Out Of Range.VI" I Modified this VI to let the LIFA use the 19 pins of Arduino ONE.
I only change the Upper limit (15) to 20, This is in the Uno case and Digital case...
(3,158 Views)
