LabVIEW Interface for Arduino Discussions
I2C: How to Read/Write AT24C01?
I tried to read data from AT24C01 but can not, an error always appears.
my code here.
Where is wrong? please help me.
Thank!
(9,282 Views)
What is the error?
(6,976 Views)
Thank for your reply,
Error message:
And my Schematic:
thank.
(6,976 Views)
Are you able to run the LED Blink example?  If no, then it's likely not related to the sensor:  http://digital.ni.com/public.nsf/allkb/8D47D6C48D0ABA0A86257884007035F1.
(6,976 Views)
Thank you,
I have successfully read and write data in AT24C01
(6,976 Views)
What did you do to fix your problem?  It's good to post your solution so that if others have a similar issue then they can find an answer.
(6,976 Views)
My problem is not correct device address.
Write and read memory AT24C01 with correct code:
(6,976 Views)
