LabVIEW Interface for Arduino Discussions
I2C issue while programming MAX6955 LED Driver chip
I am trying to communicate with MAX6955 chip. I am able to do communication via adruino IDE , but when i am trying to give same set of commands via Labview using Linx I2C module i am not able to get same results.
(4,336 Views)
For help with LINX, you should post on the LINX forums:  http://www.labviewmakerhub.com/linx
When you do post there, could you also attach the Arduino code that you know works?
(4,010 Views)
