LabVIEW Interface for Arduino Discussions
Interface Labview-arduino IMU IDG500/ADXL335
Hi everybody,
I'd like to aquire and display 6 analog signals from the http://robot-italy.com/it/new-imu-analog-combo-board-5-degrees-of-freedom-idg500-adxl33.html using Labview. Somebody can help me?
Are there some examples?
Thanks everybody
(6,010 Views)
Once you have LIFA working you simply need to hook the sensor up to the arduino and read the analog voltages with "Analog Read Pin.vi" or "Analog Read Port.vi".
(4,339 Views)
Can you post Analog Read Port.vi to download?
(4,339 Views)
No, you already have it if you have LIFA.
(4,339 Views)
Analog Read Port.vi is a part of the arduino, library (in the "low level" sub library, installed with LIFA package.
This package (as well as Visa drivers) is mandatory to interface LV and arduino...
Just to make sure : did you installed all that already?
antoine
(4,339 Views)
