LabVIEW Interface for Arduino Discussions
Interfacing Teensy 4.0 with Labview
I have recently started a project in which I need to use a Teensy 4.0 Board and because I am familiar with Labview but not much with Arduino, I thought I could try to use Labview for developing some code for sending signals and reading data from sensors.
I installed the LINX from MakerHub, but the Teensy 4.0 is not listed and I am not sure if I need to adapt something for the 4.0 or there is something already available.
Can anyone help?
Thank you in advance!!
(2,795 Views)
Dears,
Arm Mcu dominance in the world is in a wide range from amateur users to professional users. As a licensed user of NI Labview software, I have to make the following opinion. Labview software has a significant share in the development of the world. This responsibility has been demonstrated by releasing the Community Edition version. From now on, I believe/hope that it will continue by giving full support to the best selling Arm Mcu family in the world with the same sense of responsibility.
(2,748 Views)
