LabVIEW Interface for Arduino Discussions
Issue with stepper motor control
I am trying to turn a small worm drive with a stepper motor.
I am trying to control a stepper motor (CanaKit Stepper Motor) with an Arduino Uno and a easydriver. I installed everything correctly, and I uploaded LIFA to the board. I booted up the Arduino Stepper Motor.vi example program and connected the system as the diagram below the vi required.
The problem is that it doesn't work. I don't know why. If I upload a sketch to control the stepper motor on its own without using labview, it works, so I assume my hardware is fine.
I would really appreciate some help with this.
Also, I was reading on some forum posts that it is possible to send a packet of infromation to the arduino, (How many steps, how quickly, etc) and that the arduino would carry it out by using some custom code in the LIFA_Base. I was wondering if that would be a better option.
Thanks in advance,
Brian
(4,574 Views)
Hello sir
Have you been able to do the interface with the LIFA?
Hope to hear from you soon
(3,909 Views)
No unfortunately. I went about solving my problem using another method, cutting out the Labview portion.
(3,909 Views)
which method did u use sir
(3,909 Views)
