LabVIEW Interface for Arduino Discussions
LABVIEW SENSUINO EC PROBE
I am a newbie and have had some success with LIFA.  I am trying to get EC readings using the Senduino EC probe but can't quiet figure it out.  I would apprecitate any help.  If someone could point me in the right direction I will crunch awat. I posted the sketch.   Thx in advance.
#define SAMPLES 100
#define ECinputPIN 6
#define enablePIN 7
void setup() {
pinMode(ECinputPIN ,INPUT);
pinMode(enablePIN ,OUTPUT);
Serial.begin(9600);
float ECa=1;
float ECb=1;
long highPulseTime;
long lowPulseTime;
void loop() {
digitalWrite(enablePIN ,HIGH);
delay(100);
lowPulseTime=getLow(ECinputPIN);
Serial.print(lowPulseTime);
Serial.print("    ");
highPulseTime=getHigh(ECinputPIN);
digitalWrite(enablePIN ,LOW);
Serial.print(highPulseTime);
Serial.print("    ");
Serial.println(lowPulseTime+highPulseTime);
delay(2000);
long getHigh(int pin) {
long pulseTime=0;
for(unsigned int j=0; j<SAMPLES; j++){
pulseTime+=pulseIn(pin, HIGH);
pulseTime= pulseTime/SAMPLES;
return pulseTime;
long getLow(int pin) {
long pulseTime=0;
pulseTime+=pulseIn(pin, LOW);
pulseTime = pulseTime/SAMPLES;
return pulseTime;
(5,927 Views)
If the code that you posted is accurate, you will not be able to use the sensor with LIFA because LIFA does not provide the capability to use the pulseIn() function.
Also, since LIFA is no longer being developed and is very old, you should consider using LINX.  You will still probably need to request for someone to make support for the sensor but there is more activity for LINX.  If you do post, please post a link to the datasheet for the sensor you are using.
(4,229 Views)
Thanks Nathan. You have taught me a lot onhere.  Thank you for all your work!!  I will get LINX and repost.
(4,229 Views)
I use Read pulse width in LINX toolkit, works perfect.
(4,229 Views)
Awesome, that is great to hear.
(4,229 Views)
