LabVIEW Interface for Arduino Discussions
LIFA - Ethernet
Sorry I've been slacking on supporting the Ethernet-LIFA.  This is a project that I'm doing for work, so I can't fully release my code.  I'm trying to just relase the Ethernet features without giving away anything else.  I'll see what the drop box has inside of it right now and then add/remove acordingly.  I saw that the link was dead and should get one up soon.
Matt
Edit:
If someone could help me figure out what I need to get just the library installed, that would be awesome.  I just mainly need links, I cna figure most of it out from there.
Message 21 of 56
(5,689 Views)
Just so you know LINX, the replacement for LIFA supports ethernet and wifi on chipKIT devices and I intend to add support for the ethernet Arduino when I get a chance.
LINX is currently in open beta.  You can learn more and download LINX at www.labviewhacker.com/linx.
Thanks!
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
Message 22 of 56
(5,689 Views)
If Sammy_K suggests LINX, I'd go with that.  After all, he is the LIFA creator and I deffer to him.
Message 23 of 56
(5,689 Views)
sorry, "sub vi is not executable", what should i do to to solve this problem ?
Message 24 of 56
(5,689 Views)
That means that there is an error in the subVI.  You need to fix the subVI so that there are no longer any errors and has a solid run arrow.
Message 25 of 56
(5,689 Views)
i have been serching the error, but there no error in the subVI, and Init block doesn't work (error) this error
i have replaced LIFA with LIfa - ethernet
Message 26 of 56
(5,689 Views)
I'm not familiar with the things that he changed to make it work over ethernet but I'm guessing that not everything got replaced with his custom version.  To see why a subVI is not executable, you need to open the subVI in question and click the run arrow (which will be broken) to see the list of errors for that subVI.
Message 27 of 56
(5,689 Views)
Ok, thank you nathan.
did you ever success to connect lifa with ethernet or wifi shield ?
Message 28 of 56
(5,689 Views)
I've never tried (I haven't needed it and I don't have any hardware to do it with).
Message 29 of 56
(5,689 Views)
may i ask your opinion ?
i want to connect labview with arduino but this connection use wifi or IP , not serial port, what should i do with labview program ?
Message 30 of 56
(5,689 Views)
