LabVIEW Interface for Arduino Discussions
LIFA Success Stories
Do you have a LIFA success story? Share it here!
Message 1 of 9
(22,156 Views)
I just wrote a little program that uses an Arduino, Hall effect sensor, magnet, 5.6kOhm resistor, 10nF capacitor, a LED and a couple wires to read the amount of teeth of a steel gear that rotate by the sensor.  The program is simply a digital read and count, but with the Hall effect sensor and gear it acts like a single line relative encoder and only and cost ~$45 in hardware.  It also lights the LED describing the state of the Hall Effect sensor.  Good times.
Message 2 of 9
(12,933 Views)
jdskier1,
That sounds awesome.  Can you post some picstures or a video?  I would love to see it in action.
Sam K
LIFA Developer
Message 3 of 9
(12,933 Views)
I've used LIFA to develop a topside GUI for my homebuilt ROV. Spent a year trying to get VB6 to do what it took me a week to do with LIFA.
Great toolkit guys!
Quantum Mechanic at Large
Message 4 of 9
(12,933 Views)
I'm using LIFA for my mechanical engineering senior capstone project. I'm using the Arduino Uno+Labview along with some sensors and LEDs to increase efficiency on a manufacturing process. Having Labview is great because it makes my job way easier. Thanks for making this!
Message 5 of 9
(12,933 Views)
I intergrate LIFA to my ongoing project. It's a project to control a electric bike which consists a BLDC motor for the wheel.
I use OSC (open sound control) to control the speed of the bike from my iphone.
The wheel is from amped bike
http://ampedbikes.com/kits.html
Labview recieves speed command from the iphone than send it to the arduino. Based on the required speed, the arduino control the BLDC by a motor driver shield.
For OSC i use the framework from here:
https://decibel.ni.com/content/docs/DOC-12289
With some minor change, i have this front end:
And here is the back end
It works great!
ps: I'm new to labview and still learning. If you work with labview and OSC before please contact me, i have some question that may be you can help.
taro10h@gmail.com
Message 6 of 9
(12,933 Views)
I developed what we called Production Performance Monitor...which basically is a GUI to indicate, instant ciclye time, avg, cycle time, quality defects counter, it graphs the pieces per minute produced on the line..plus it saves it to a TXT file for analisys on excell..
the arduino is conected to a signal on the plc that makes a pulse every unit pass through the machine at the end of the line..it also has buttons to clear indicators and reset quaility defects counter..
CLAD, CTD
Message 7 of 9
(12,933 Views)
At Iowa State University, we successfully used Arduino Mega 2560 with a customized version of LIFA to compete in NASA's Lunabotics Mining competition (May 2012).
Message 8 of 9
(12,933 Views)
Our company owns a quite old concrete batch plant, which had full manual control requiring an operator to control 14+ switched and observe 3 mechanical scales. I was successful to upgrade this plant to an automated unit requiring minimal operator input using custom made Arduino Uno compatible board and LIFA. Wiring is still messy which I shall take care in the near future after all testing is done.
Control Unit for the plant
The VI
The plant.
Message 9 of 9
(12,933 Views)
