LabVIEW Interface for Arduino Discussions
LIFA ethernet to USB
anotheralias wrote:
(I think you might need to use multiple ports, though(someone chiime in on wether it is possible to have multiple arduino endpoints in the mix on one channel before hubbing out?
As long as each Arduino has a different COM port in Device Manager, you can hook up as many as you want.  Last year, I wrote custome firmware and LabVIEW functions to automatically detect all Arduino's connected and and I gave each it's own identity (just in case they didn't end up on the same COM port).
I'm not sure how all this network stuff will work out with the device you linke to but as a long as the device shows up as a serial device in Device Manager with a working COM port, LabVIEW should work as it won't be able to tell the difference.
Message 11 of 12
(957 Views)
I'm reviving an already answered thread here.
I finally got ethernet communications working with LIFA.  The information can be found on this post: https://decibel.ni.com/content/message/50372#50372.
Matt
Message 12 of 12
(957 Views)
