LabVIEW Interface for Arduino Discussions
LabVIEW comm connection
I can up load the Arduino firmware to the Arduino Uno however, when I go to the INIT.VI icon in LabVIEW the VISA Resource
does not show my comm port. I check my Device Driver and it shows the Arduino Driver on comm 6 and working correctly
but I cannot connect the LabVIEW program  to the Arduino board, by the way I have no probems when running the program on the
VISTA operating system, the problem presents itself on the WIN 7 and XP system.
(3,592 Views)
Johnweic,
Can you post a screenshot of our issue.
Do you have NI-VISA installed?  Can you see the Arduino COM port in MAX?  Is it possible something else is using your Arduino (for example you must have the Arduino serial monitor closed to use the Arduino in LV)
-Sam K
LIFA Developer
(3,234 Views)
