LabVIEW Interface for Arduino Discussions
LabVIEW interface with a general purpose board...
Hello....
I have successfully interfaced Arduino UNO board with LabVIEW software and simulated an LED on-off example correctly by flashing the board with LIFA_base firmware.. I am just wondering, how can we interface a general purpose microcontroller board with LabVIEW as the library for the same is not available unlike Arduino UNO. How to do this ?? Plz suggest me something....
(4,401 Views)
Hi!
You can use the "VISA configure serial port" to interface your microcontroller with LabView. Of course, you need to write a program to comunicate the board with LabView and you need a signal converter, like the MAX232.
Here you can find some links that can help you to create the interface.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1jtCAA&l=en-US
https://www.youtube.com/watch?v=RZe3m8zkSl4
And if you are using a microcontroller that supports USB communication, here you have another suggestion to interface it with LabView.
https://www.youtube.com/watch?v=QnxGS35XD64
All the information is in Spanish but there are a lot of tutorials in English.
Regards.
(3,801 Views)
There are two approaches one can use to use Labview with a general purpose micro controller.  You can use either remote program calls, RPC,  or you can write a program that performs a single task.  With RPC you write a  multi function program that will execute your required tasks.  LIFA is an example of a RPC program.   Most any  Arduino program you find in books are single task programs.   Both approaches will use Labview's Serial Communication capability.
This web page <https://developer.mbed.org/cookbook/Interfacing-with-LabVIEW> shows both approaches for a LPC1768.
hrh212
(3,801 Views)
