LabVIEW Interface for Arduino Discussions
Labview+Arduino+TVremote+Tsop sensor
Good morning reader,
I want to control my home automation system by using a TV remote control with the help of Labview2011 with hardware interfacing media as Arduino Mega2560 (R3).
Kindly provide me support regarding it.
Thank you.
Message 1 of 8
(10,485 Views)
What sensor do you have?  What protocol does it use to communicate?  Does there already exist Arduino code for this sensor that you have?  More details are needed to help you out.
Message 2 of 8
(6,710 Views)
I am using IR and Tsop sensor, for sending and receiving.
I have no any existing code for it.
Message 3 of 8
(6,710 Views)
hello if you need information dobre TSOP IR sensor, you can check these links soon I will buy the same sensor to make some projects so I was looking for information, the links are:
http://electronicavm.wordpress.com/2011/09/20/recepcion-ir-con-arduino-protocolo-nec/
http://learn.adafruit.com/ir-sensor/using-an-ir-sensor
Message 4 of 8
(6,710 Views)
Sir, I read out all about IR & Tsop sensors but still facing problem regarding programing of Tsop sensor based output and i am not able to utilise the output of Tsop sensor in LIFA toolkit.
So, kindly provide me suggestion regarding this.
Thank you.
Message 5 of 8
(6,710 Views)
LabVIEW_007
What have you tried?  We're always happy to help answer your questions but we need to know what you've done and what you're having trouble with.  If you're looking for high level guidance there is some good info about IR communication here and google is always a good place to start.
Good luck!
-Sam K
LIFA Developer
Message 6 of 8
(6,710 Views)
hello, as I told you not yet bought the sensor but I recommend that you first do you achieve communication arduino native language, when this can get LIFA try, you will find more information on the internet, more links attached
Product Data Sheet
https://www.sparkfun.com/datasheets/Sensors/Infrared/tsop382.pdf
Tutorial
https://www.sparkfun.com/tutorials/291
Code
https://www.sparkfun.com/datasheets/Components/General/Cheapo_IR_Control.pde
Message 7 of 8
(6,710 Views)
Hi LabView_007,
Did you manage to find a solution for this question. I am currently working on a similar project. Any help would be appreciated.
Message 8 of 8
(6,710 Views)
