LabVIEW Interface for Arduino Discussions
Labview and MAX31865 SPI problems
I should use Labview to measure temperature via a four wire Pt100, with a MAX31865 sensor that use an SPI intarface.
Unfortunately Labview does not have an example VI for this sensor and I have not found anything working online.
I know a little about Labview but nothing about Arduino
I have read everything I found on the SPI and Arduino but I can't solve the problem.
Using Arduino IDE (with the attached scetch) the system works, so the hardware is OK.
On Labview I am using LINX, (loading LINX firmware for Arduino Uno) but I can only read constant values that vary according to the values of the bytes I write in the register.
Probably I make mistakes in writing the configuration on the Arduino register, but given my experience it could be anything else!
From what I understand, reading the sensor data sheet, the library and the Arduino schetch and looking online, in registers from 7 to 0 Byte 10100011 must be written.
I've tried all the ways but can't get reasonable measurements.
Can anyone give me some tips?
I attach the VI labview and Arduino libraries for Max31865 sensor. The system does not allow me to attach the schetch, not even in .txt format!
Thank you very much
Message 1 of 10
(8,280 Views)
Message 2 of 10
(8,215 Views)
The max6675 does not require writing data to the configuration register, as it does in the max31865.
I think I am wrong in writing in the register!
Many thanks for your interest
Message 3 of 10
(8,197 Views)
I had the same problem some months ago.
I needed to interface the MAX31865 with muRIO 1900, and ididdn't found any example, so decided to create a code, and it works.
Message 4 of 10
(8,027 Views)
is possible to upload configuration.vi write.vi and write read.vi of your vi because i am trying to change your vi to use a arduino instead of my rio to read a rtd sensor
thanks omar
Message 5 of 10
(8,015 Views)
Many thanks, I'll try to use it
Message 6 of 10
(8,005 Views)
ok,
if you have some problem or questions plese do not hesitate to contact me again
Message 7 of 10
(8,001 Views)
Hi Omar,
Were you successful to convert it to Arduino with LINX?
Chung
Message 8 of 10
(7,015 Views)
no but i'm trying
when i do that i publish the solution
Message 9 of 10
(7,002 Views)
Hi Omar,
I have made this far. Can you take a look at this VI. I basically copy the sequence the Short Read_RTD Max31865 replacing LINX SPI vis.
I got some numbers but they are not the data from the memory.
Chung Hoon
Message 10 of 10
(6,997 Views)
