LabVIEW Interface for Arduino Discussions
Labview interface with arduino adafruit flora
Hi friends,
I am trying to interface arduino adafruit flora with labview. Please help me with the links.
Thank you,
(5,696 Views)
Where is Links??
(4,744 Views)
I don have the links.
I just know that interfacing is possible with arduino Uno. Is it possible with adafruit?
(4,744 Views)
I dont know about this.But you can try to interfacing it with LabVIEW  and then came to know..
Look at this  also https://labviewhacker.com/doku.php?id=libraries:linx:linx
(4,744 Views)
Thank you. Actually i have already done interfacing with arduino Uno. But i like to use Adafruit flora.
(4,744 Views)
Neither LIFA nor LINX are designed to work with any Adafruit boards.  If it communicates with Serial communication via a virtual COM port, you can use the VISA VIs just like LIFA does.  However, you would need to design everything that you need.
(4,744 Views)
Thank you
(4,744 Views)
