LabVIEW Interface for Arduino Discussions
Lm 35DZ
Hi all,
I used the arduino  thermistor example in labview.
I have an Lm35DZ with 3 pin so the schematic of the example isn't the same because change the pin.
I put the pin 1 to arduino +5V
Pin 3 to arduino gnd
Pin 2 is output of thermistor,so I connected it with a 10k resistence to ground of bread board,and another wire from output to analog 0.
The problem is that I read in labview -30Celsius!!
Anyone know why?
(4,333 Views)
  1. Have you tried measuring the output directly using a multi meter against a known temperature?
  2. Also apply a known voltage to analog 0 and see what your program reports back.
We could help you better if you posted your code.
Regards.
(3,817 Views)
hi,
thanks for reply.
I tried with multimeter and work well but I haven't tried sending a known voltage to analog 0,I'll try
(3,817 Views)
The code is simply the thermistor example of arduino toolkit!
(3,817 Views)
