LabVIEW Interface for Arduino Discussions
Multiple analog input and display
HI
I am very new to LAB view and went over the examples that come with VI package manager. I was able to succesfuly run and test the example "Arduino Analog Read Pin". I would like to be able to read two different analog inputs at the same time and display them on two different voltage GUI. So basically exactly like the example but two.
(5,328 Views)
Another image
(5,113 Views)
LIFA is old and deprecated.  You should use the replacement called LINX.  Reading multiple analog pins will actually be faster with LINX.  If you have questions regarding LINX, please post on the LINX forums and we'll try to help you out.
(5,113 Views)
Please help me I want to give input to Arduino through DAQ
(5,113 Views)
