LabVIEW Interface for Arduino Discussions
Où sont les programmes pour arduino...
Bonjour,
Je cherche les programmes arduino qui correspondent aux exemples dans les JKI VI Package manager....
merci de me repondre
Message 1 of 9
(5,404 Views)
There is a subpalette called "Examples" on the Arduino palette (on the block diagram).
Message 2 of 9
(4,382 Views)
Thank you Nathan... i know where are the examples but, my problem is following:
- I can compile the Lvifa_base to my Uno
this is the message when i try:
LVIFA_Base.cpp.o: In function `loop':
C:\Program Files\Arduino/LVIFA_Base.ino:59: undefined reference to `checkForCommand()'
C:\Program Files\Arduino/LVIFA_Base.ino:65: undefined reference to `sampleContinously()'
LVIFA_Base.cpp.o: In function `setup':
C:\Program Files\Arduino/LVIFA_Base.ino:39: undefined reference to `syncLV()'
Can you say sometinng please?
Message 3 of 9
(4,382 Views)
read i can't  compile the uno please!
Message 4 of 9
(4,382 Views)
You should use LINX instead of LIFA.  LINX does not require you to compile any code or use the Arduino IDE (using the Firmware Wizard).  Also, LIFA is no longer officially supported.  Check out the release announcement for LINX and visit the LINX website:
LIFA Replacement - LINX Officially Released
Message 5 of 9
(4,382 Views)
I second Nathan's suggestion about using LINX.  But with regards to LIFA I suggest you use the VI Package Manager to make sure you have the latest version of the LIFA firmware.  It is 2.2.0.79.  Version 2.2.0.79 and         Arduino IDE 1.0.5-r2 works for me.
hrh1818
Message 6 of 9
(4,382 Views)
Thank you Nathan, I install LINX and 3 lines appear in the VI package, but the examples Arduino Analog Read pin.vi refuse to work.
Have you another idea please.
Message 7 of 9
(4,382 Views)
I recommend going through all the tutorials available at the LINX website.  Then, if you still can't get it working, post a new thread on the LINX forums to get help.
Message 8 of 9
(4,382 Views)
Hello Nathan,
Thank you for your suggestion, i reinstall, NI Vi package and the Arduino, now it work with the examples....
I will continue by reading in the LINX forum ...
Bonjour Nathan ,
Merci pour ton aide , j'ai pu faire marcher ma carte UNO avec Labview+ LINX....
J'ai tout réinstallé:  NI, VI package et la carte arduino aussi...
J'ai pu faire fonctionner les exemples BLINK et le potentiomètres....
Voilà je vous remercie tous!
Message 9 of 9
(4,382 Views)
