LabVIEW Interface for Arduino Discussions
One Wire Sensor for LINX
Hello, my name is Jesús Galindo.
I am having trouble because I am using the DS18B20 sensor and I can't get Labview to read the temperature.
I was watching some other posts about that, but they were referring to LIFA. And I am using LINX.
What can I do in this case? How could I adjust something to get this done?
Thanks in advance!
(6,673 Views)
Regardless of which you use, you would have to add a custom command to communicate with the sensor.  If you look at the code that has been posted for LIFA, you can port that over to a custom function in LINX (there is a custom function tutorial for LINX on the LINX website).
For help regarding LINX, post on the LINX forums.
(5,383 Views)
hey, just a short answer, i have to hurry up a little bit...
have a look at this: https://www.labviewmakerhub.com/forums/viewtopic.php?f=12&t=295
Michael
(5,383 Views)
