LabVIEW Interface for Arduino Discussions
Pressure transducer and Arduino
Hi folks...
Am using LIFA/Arduino to measure a 4-20mA output from a pressure transducer (0-160bar).
All working well (using a current sense resistor across a analogue input) - but what I would now like to do is measure the rate of change of pressure (say delta P per minute) - Now I'm sure there is a very straight forward way of doing this but
my mind is in a fog currently as to how.........
Any ideas out there???
cheers
Dave
(4,937 Views)
Labview's shift registers can be used to store previous samples and you can use the shift register to make a simple differentiator by taking the difference between the present value and a previous value.  I f you are not familiar with shift registers do a Google search on the phrase "Labview Shift Register".
The following link shows a more sophisticated Digital Differentiator.
<http://www.dsprelated.com/showarticle/35.php>
hrh1818
(3,991 Views)
Thanks hrh 1818...
After entering my question I did do some further reading up and found the answer as you have stated - Good ol shift registers. Have it setup now and appears to be working. Thanks for your answer..
Dave
(3,991 Views)
