LabVIEW Interface for Arduino Discussions
Problem connecting labview with Arduino uno.
Take a look at the official error documentation first and see what it suggests.  Also, there are many posts about this error, you could search for those and see what their solutions were.
Message 11 of 14
(1,966 Views)
Hi evereyone, i've got the same problem as "tuppa". Have you finally solved it? Thank You in advance, Fred.
Message 12 of 14
(1,966 Views)
hey, i've got the same problem. When I try to fix 5002 error and run the labview again, I found error 5003. Then I try to fix 5003 error and run the labview again. But, the result I found -1073807343 error. What should I do? any ideas?
Message 13 of 14
(1,966 Views)
Hi, please check up whether you used Close.vi to release the data flow.I got the same problem before.
Message 14 of 14
(1,966 Views)
