LabVIEW Interface for Arduino Discussions
Problem with xbee, arduino and labview
Hello to everyone
Im trying to communicate two xbee boards with arduino and labview. the two xbee modules are set to work with the same baud rate (9600).
The first xbee module is conected to my laptop by a usb-xbee board and the other one is conected with arduino uno board by the wireless proto shield with its xbee module.
Im trying to read an analog value from a potenciometer, but when I run the program with labview, I see the leds blinking of the two boards, but labview show me an error with the conection.
Im using labview 2013, and I have a question, I saw in other post about some problems with xbee and labview using LIFA, they say that the file labviewinterface.h have to be modified in the baud rate,
so my question is, do I have to modify the baud rate in the file labviewinterface.h if Im using labview 2013?
I will let you guys some pictures about the modules and an screen picture about the error.
I hope you can help me
(5,524 Views)
You have to modify the baud rate in both the firmware (the .h file) and in LabVIEW (by wiring the appropriate value to Init.vi).  This is not dependent on LabVIEW version (meaning it doesn't matter what version of LabVIEW you are using).
(4,803 Views)
hello , Thanks for the answer.
Can you tell me what I need to modify? Im not sure how to doit.
this is the code from the Labviewinterface.h
#define DEFAULTBAUDRATE 9600// Defines The Default Serial Baud Rate (This must match the baud rate specifid in LabVIEW)
#else                                                     <------- Do  I delete this line?
#define DEFAULTBAUDRATE 115200       <------- Do  I delete this line?
#endif                                                     <------- Do  I delete this line?
when you say, that I need to wire the appropiate value, is in this part right?  ?
I hope you can help me, I still having the same problem, and I dont know why
(4,804 Views)
If you are using an Arduino Uno, you need to change the second DEFAULTBAUDRATE definition to 9600:
I.e.
Change:
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#define DEFAULTBAUDRATE 9600    // Defines The Default Serial Baud Rate (This must match the baud rate specifid in LabVIEW)
#else
#endif
to:
#else
#endif
The first one is for the Arduino Mega and the second one is for everything else (including the Arduino Uno)
(4,804 Views)
Hello, thans for the answer
I modified the LAbviewinterface.h file with the baudrates, But Im still having the same problem
I tested the two xbee modules without the labview and they work perfectly. I dont know why I have the problem to communicate with labview
do you have any ideas?
I will leave you my vi file, I hope you can check it . Im using arduino uno.
I hope you can help me.
(4,804 Views)
