LabVIEW Interface for Arduino Discussions
Property node of digital write with labview mobile
I am trying to connect a the arduino with a bluesmirf RN-42 via  windows mobile 6 and cannot connect. With the digital write vi there is a vi named checked for pin out of range when I try to compile that under windows mobile  and It says property node not supported in current target.There is a picture of the vi below and I have attached the  "check for pin out of range.vi'. The property nodes that are not working are the names and callers in the digitial/analogue loop. Is there any way around this?
Any help is greatly appreciated
Canalian
(4,106 Views)
Canalian,
  We never did any verification on LabVIEW for Mobile in regards to LIFA. The picture you attached did not show up but I imagine the only property node used is a VI Server property used to identify the VI for error checking. If this is the only issue with porting your application to a mobile device, I would actually recommend deleting every instance of the Check for Pin Out of Range. Using this you will have to do pin range checking by hand (essentially making sure on a Uno that you don't use Digital line 20) but it will get rid of this issue.
-Ben
Ben J.
(3,325 Views)
