LabVIEW Interface for Arduino Discussions
RS232 Communication Arduino/Computer
I wan't to communication thru RS232 .
Thank
(7,930 Views)
A bit more information would help us debug this.  Don't work is not much to go on but...
Did you select the correct COM port for the visa constant on the Arduino Init VI when using the USB to RS232 Dongle?
Does the RS232 adapter use TTL logic levels?
Please describe in great detail the errors / problems that you have when using the USB/RS232 dongle.
Thanks!
-Sam K
LIFA Developer
(4,416 Views)
It's work.
Thank
-Sam K
(4,416 Views)
Can you describe the problem and the solution incase anyone else wants to do something similar?
Thanks.
-Sam K
LIFA Developer
(4,416 Views)
configuration hardware + libraries + USB converter TTL = good
(4,416 Views)
