LabVIEW Interface for Arduino Discussions
Reading SPI of MAX31855
As raw data I get 0111 1111 1111 1101 0010 0011 0011 0000 - running your VIs.
Message 51 of 131
(7,262 Views)
The datasheet says that the chip assumes a linear relation; the different models just account for the different Seebeck coefficients. That's at least the way I understand the datasheet, but of course I hope that I'm wrong. Maybe it uses several linear functions for different temperature ranges...
On the other hand - if I'm reading it correctly - it states that the maximum error is +/- 6°C.
Tomorrow I'll know for sure, because then I can test it with a type S TC; until now I've used a type K, for comparisons sake.
Message 52 of 131
(7,262 Views)
I run your VIs, and everything is working.
Message 53 of 131
(7,262 Views)
I edit the lifa firmware in the arduino program. I did edit the LabVIEWInterface.pde so my changes should be in there but I don't know how you do it in lavbiew and get the diff file.
NathanB. wrote:
Samething that I did, essentially, for just the TC data except you failed to include the LIFA firmware.
Message 54 of 131
(7,262 Views)
I see what happened.  You let your Arduino IDE change the extension (which I do not) so when I opened the lvlib those files were "missing".  So, The one thing that I notice is that you send the least significant byte first but then use it as the most significant byte in LabVIEW (the "hi" argument of the "Join Numbers" function).
To create the .diff file, I use the Linux diff command on my Linux box.  I will start adding them to my custom LIFA firmwares so that people can glance only at what was added/changed.
Message 55 of 131
(7,262 Views)
The first two bytes look fine.  The second two bytes I'm not too sure because if the circuit is open the first bit (on the far right) should be 1.
I didn't see that note about non-linearity.  That is unfortunate.
Message 56 of 131
(7,262 Views)
I have purchased the Max 31855 board from Ada Fruit and am using it with my Uno and Mega.  The board is described here:
http://www.adafruit.com/products/269
Using the vi above I am getting zero as a reading.  I tried to troubleshoot a bit but figured I would ask a couple questions as well.
1. Do I need to be using the custom LIFA base above, or will the current LIFA base work with this VI?  I did not reload and am using the current base.
2. The ADA Fruit breakout board has a bit different markings than the VI. I assume that DO on the ada board is SO pin in vi, assume that CLK on board is SCK in vi, and assumed that CS was CS both places.
Any inputs to get me up and running here?
Cheers
Message 57 of 131
(7,262 Views)
yes you do need to load the custom base it has the code needed to talk to the MAX chip and you are correct about the pin assignment.
Message 58 of 131
(7,262 Views)
Thanks.  So what changes were made in this base file?  I am using the current base file in the project.  If I re flash to this should I expect other issues to show up due to the base file change?
Message 59 of 131
(7,262 Views)
added cases for the max chip and this vi. Unfortunatly my laptop that had everything on has crashed and I lost all my files. so I can't go thru them and compate but the base file is capable of being opened and edited with the arduino editor there will be 2 sections that say MAX31855 you might be able those to sections over to the newest base and get it working.
Message 60 of 131
(7,262 Views)
