LabVIEW Interface for Arduino Discussions
Reading a MMA7660FC 3 Axis Accelerometer connected to Arduino Uno
Hello everyone. I am curretly working on a project to control the yaw, pitch and roll axes of a robotic gimbal wrist using an Arduino UNO and a LabView interface.
In a nutshell, I want to read data from a MMA7660FC 3-axis accelerometer connected to the Arduino UNO via I2C using LIFA, process the data, and then send it back to the Arduino UNO for driving the motors.
I have the MMA7660FC accelerometer connected to the Arduino Uno communicating via I2C. I am able to read the axis values with the Arduino IDE, but I need to read the values from each axis with LabView.
Any suggestions?
Message 1 of 9
(14,202 Views)
If you post the working Arduino code for the accelerometer, it will be easier to port it over to LabVIEW.
Message 2 of 9
(10,061 Views)
I downloaded a library for the MMA77660FC. The code I've been using just calls on the library.
#include <Wire.h>
#include "MMA7660.h"
MMA7660 accelemeter;
void setup()
          accelemeter.init();
          Serial.begin(9600);
void loop()
          int8_t x;
          int8_t y;
          int8_t z;
          float ax,ay,az;
          accelemeter.getXYZ(&x,&y,&z);
          Serial.print("x = ");
    Serial.println(x);
    Serial.print("y = ");
    Serial.println(y);
    Serial.print("z = ");
    Serial.println(z);
          accelemeter.getAcceleration(&ax,&ay,&az);
    Serial.println("accleration of X/Y/Z: ");
          Serial.print(ax);
          Serial.println(" g");
          Serial.print(ay);
          Serial.print(az);
          Serial.println("*************");
          delay(500);
Message 3 of 9
(10,062 Views)
This is the accelerometer register overview http://www.freescale.com/files/sensors/doc/app_note/AN3837.pdf
Message 4 of 9
(10,061 Views)
Can you please either attach the full working code (i.e. with library) or link to same files?
Message 5 of 9
(10,062 Views)
Thanks for your replies Nathan, I really appreciate your help on this.
Here it goes.
Link to the  downloadable library:
http://www.seeedstudio.com/wiki/File:DigitalAccelerometer_MMA7660FC.zip
Link to the accelerometer register chart:
cpp file   MMA7660.cpp :
#include <Wire.h>
/*Function: Write a byte to the register of the MMA7660*/
void MMA7660::write(uint8_t _register, uint8_t _data)
          Wire.begin();
          Wire.beginTransmission(MMA7660_ADDR);
          Wire.write(_register);
          Wire.write(_data);
          Wire.endTransmission();
/*Function: Read a byte from the regitster of the MMA7660*/
uint8_t MMA7660::read(uint8_t _register)
          uint8_t data_read;
          Wire.begin();
          Wire.requestFrom(MMA7660_ADDR,1);
          while(Wire.available())
                    data_read = Wire.read();
          return data_read;
void MMA7660::init()
          setMode(MMA7660_STAND_BY);
          setSampleRate(AUTO_SLEEP_32);
          setMode(MMA7660_ACTIVE);
void MMA7660::setMode(uint8_t mode)
          write(MMA7660_MODE,mode);
void MMA7660::setSampleRate(uint8_t rate)
          write(MMA7660_SR,rate);
/*Function: Get the contents of the registers in the MMA7660*/
/*          so as to calculate the acceleration.            */
void MMA7660::getXYZ(int8_t *x,int8_t *y,int8_t *z)
          unsigned char val[3];
          int count = 0;
            val[0] = val[1] = val[2] = 64;
          while(Wire.available() > 0)
                    Wire.read();
          Wire.requestFrom(MMA7660_ADDR,3);
              if(count < 3)
                          while ( val[count] > 63 )  // reload the damn thing it is bad
                    val[count] = Wire.read();
        count++;
          *x = ((char)(val[0]<<2))/4;
            *y = ((char)(val[1]<<2))/4;
            *z = ((char)(val[2]<<2))/4;
void MMA7660::getAcceleration(float *ax,float *ay,float *az)
          int8_t x,y,z;
          getXYZ(&x,&y,&z);
          *ax = x/21.00;
          *ay = y/21.00;
          *az = z/21.00;
library code  MMA7660.h
#ifndef __MMC7660_H__
#define __MMC7660_H__
#define MMA7660_ADDR  0x4c
#define MMA7660_X     0x00
#define MMA7660_Y     0x01
#define MMA7660_Z     0x02
#define MMA7660_TILT  0x03
#define MMA7660_SRST  0x04
#define MMA7660_SPCNT 0x05
#define MMA7660_INTSU 0x06
#define MMA7660_MODE  0x07
          #define MMA7660_STAND_BY 0x00
          #define MMA7660_ACTIVE           0x01
#define MMA7660_SR    0x08         //sample rate register
          #define AUTO_SLEEP_120          0X00  //120 sample per second
          #define AUTO_SLEEP_64          0X01
          #define AUTO_SLEEP_32          0X02
          #define AUTO_SLEEP_16          0X03
          #define AUTO_SLEEP_8          0X04
          #define AUTO_SLEEP_4          0X05
          #define AUTO_SLEEP_2          0X06
          #define AUTO_SLEEP_1          0X07
#define MMA7660_PDET  0x09
#define MMA7660_PD    0x0A
class MMA7660
private:
          void write(uint8_t _register, uint8_t _data);
          uint8_t read(uint8_t _register);
public:
          void init();
          void setMode(uint8_t mode);
          void setSampleRate(uint8_t rate);
          void getXYZ(int8_t *x,int8_t *y,int8_t *z);
          void getAcceleration(float *ax,float *ay,float *az);
#endif
Message 6 of 9
(10,062 Views)
I was working on doing this for you but my desktop fatally crashed last night so I will have to start over.  FYI.
Message 7 of 9
(10,062 Views)
Ok, I've redone the small library.  It is purely based on the library that you linked to.  Let me know if you experience any issues.
Message 8 of 9
(10,062 Views)
Brilliant, thanks for your help, Nathan.
I'll get working on it and give you feedback as soon as possible.
Message 9 of 9
(10,062 Views)
