LabVIEW Interface for Arduino Discussions
Reason why there is "a timeout occurred while waiting for the to respond"
Hi, i am new user in LabVIEW.
I try to connect LabView with Arduino UNO using LINX.
But when i want to run it, there is an announcement "A timeout occurred while waiting for the to respond" in VI LINX Close.
Is there anyerror in my diagram block ? Or i used the wrong VI ?
I hope you can explain it as detailed as possible. Thank you
(6,132 Views)
For questions regarding LINX, you should post on the LINX forums at http://www.labviewmakerhub.com/forums
(5,477 Views)
