LabVIEW Interface for Arduino Discussions
Revise LIFA for MCP 4822
I just revise LIFA code for MCP 4822 following this post.I will test it tomorrow morning in the morning. Now I just post it out and I am not sure whether it is correct or not.
Someone has already created MCP 4822 arduino library which is pretty good. You can download it from here.
The Example code is as below
#include <SPI.h>
#include "mcp4822.h"
#define AOUT_CS A1
#define AOUT_LDAC A3
MCP4822 analogOut = MCP4822(AOUT_CS,AOUT_LDAC);
void setup() {
    // Setup serial and SPI communications
    Serial.begin(115200);
    analogOut.begin();
    SPI.setDataMode(SPI_MODE0);
    SPI.setBitOrder(MSBFIRST);
    SPI.setClockDivider(SPI_CLOCK_DIV8);
    SPI.begin();
    // Configure analog outputs
    analogOut.setGain2X_AB();
void loop() {
    static int cnt=0;
    analogOut.setValue_A(cnt);
    cnt += 20;
    if (cnt > 4095) {
        cnt = 0;
The example is straightforward. I could get an output voltage from DACa through setValue_A method. So, I would like to create a VI with one parameter which is voltage(0-4095).
1. Revise LabVIEW base
I added serveral code:
// Variables
unsigned int retVal;
int sevenSegmentPins[8];
int currentMode;
unsigned int freq;
unsigned long duration;
int i2cReadTimeouts = 0;
char spiBytesToSend = 0;
char spiBytesSent = 0;
char spiCSPin = 0;
char spiWordSize = 0;
Servo *servos;
byte customChar[8];
LiquidCrystal lcd(0,0,0,0,0,0,0);
MCP4822 analogOut(A3,A0);
Create on MCP4822 object first. A3 is CS pin, A0 is LDAC pin
case 0x2E: // MCP4822 support
      analogOut.setValue_A(command[2]);
      break;
I added serveral line here as Example does. command[2] is the set voltage.
And then,I create a new VI:
The number for MCP4822Write is 46, which equals to 0x2E.
I am not sure this is correct, so please help me if you find something wrong with it. Thank You!
Message 1 of 11
(9,220 Views)
You didn't initilize the object correctly (i.e. Your method doesn't match that of the example).
Also, this would be more appropriate in your original thread.
Message 2 of 11
(5,614 Views)
So I should follow that. Are there any other wrongs?
Message 3 of 11
(5,614 Views)
Nothing that is obvious as far as I can tell.  The best thing to do is just test it, IMO.  If it works then great.  If not then it's time to try and debug it.
Message 4 of 11
(5,614 Views)
Thank you!
Message 5 of 11
(5,614 Views)
HI, Nathan, it doesn't work
Message 6 of 11
(5,614 Views)
What didn't work?  Does the code compile for Arduino?  Does the code run on Arduino?  Do other functions via LabVIEW work with the code that contains the new additions?
Otherwise, I can't help you without your code.
Message 7 of 11
(5,614 Views)
Hi, Nathan, this is my whole code.
#include <SPI.h>
#define AOUT_CS A1
void setup() {
    analogOut.begin();
    SPI.begin();
void loop() {
    static int cnt=0;
    cnt += 20;
    if (cnt > 4095) {
        cnt = 0;
This is the original MCP4822 example.
Based on that, I added extra codes to LABVIEWInterface.pde as follows
1. Define CS pin and LDAC pin, also included the library.
#include <Wire.h>
#include <SPI.h>
#include <LiquidCrystal.h>
#define AOUT_CS 10
2. Create one MCP4822 object at variable area
// Variables
int currentMode;
unsigned int freq;
char spiCSPin = 0;
Servo *servos;
byte customChar[8];
3. create serveral case for begin(), setGain2X_AB(), and setValue_A();
case 0x2E:
          analogOut.begin();
          Serial.write('0');
          break;
          case 0x2F:
            Serial.write('0');
            break;
            case 0x34:
            Serial.write('0');
            break;
This what I have done for firmware. Can you find something wrong?
Message 8 of 11
(5,614 Views)
Did you try it?  At what point does it not work? E.g.  Does it compile?  Do you get any errors?
Message 9 of 11
(5,614 Views)
Yeah, i tried tha. It compiled, no errors but not work
Message 10 of 11
(5,614 Views)
