LabVIEW Interface for Arduino Discussions
SPI Arduino MEGA 2560 + LabView
excuse me, it was 5 us
Message 11 of 16
(2,614 Views)
That is strange that you would get that error with my VI.  Did you use my VI unmodified?  If yes, I would try and probe the "SPI Data" wire and the output of "Array Size" in "SPI Send Receive.vi" while it's running to see what is actually being sent to the subVI.
Message 12 of 16
(2,614 Views)
Yes, I used your VI unmodified.
I just got a good CS in pin 53. I tried with several DIO pins.
Later I check all block diagram for any problem to SPI Data because I always got the 8 most significant bits.
00101010
Message 13 of 16
(2,614 Views)
Any DIO pin should work for the CS (Chip Select).  Pin 53 is designated as SS (Slave Select) which is only required when the Arduino is being used as a SPI slave device.
Message 14 of 16
(2,614 Views)
I am going to do proofs today again.
Later I write you how they were
Message 15 of 16
(2,614 Views)
Hello Nathan. Today I got those signals at oscilloscope.
I tried transfering 1100101010101010.
Yellow signal is SPI Data (pin51) and blue signal is clock signal.
I don't know why bits sent don't have a continous transfer...first 8 MSB are sent.
Message 16 of 16
(2,614 Views)
