LabVIEW Interface for Arduino Discussions
SPI control of AD5231 digital pot
I'm having trouble getting this to work. I get 000 data response. If I could just get one command working I should be OK. I wrote the command generator using the AD5231 truth table as a visual reference, figuring that would be easiest. Any ideas? Thanks in advance.
PaulG.
Retired
(4,475 Views)
There are a few things that I notice:
You have a clock frequency of zero (0).
I think the device is CS "Active Low".
The frame size needs to be 3 [bytes] as far as I can tell.
For further help when using LINX, I highly recommend posting in the LINX forums.
(3,605 Views)
