LabVIEW Interface for Arduino Discussions
Serial port and Arduino
Hi - A question for the group..
I currently have a pretty basic voltage monitoring vi setup using an Arduino with LIFA.
Would it be possible to have the vi monitor a further serial port aswell? So I basically want to indicate on the front panel the results of the arduino voltage monitoring and any incoming serial data on the serial port. Is that possible ?
cheers
Dave
(4,274 Views)
Are you wanting additional data over serial from the Arduino or a second serial device? If it is a second device, is it connected to the Arduino or directly to your computer?
LabVIEW can easily connect to multiple serial devices on a single computer. Just open a new VISA session configured for the appropriate port.
(3,780 Views)
Hi - Thanks for the reply.
No the idea was for Labview to monitor a seperate serial port. While the Arduino is connected via USB..
d
(3,780 Views)
Take a look at the "Continuous Serial Write and Read" example.
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\Instrument IO\Serial\Continuous Serial Write and Read.vi
(3,780 Views)
