LabVIEW Interface for Arduino Discussions
Simple help :)
hi every body
i'm a arduino user but
sorry i'm beginner in labveiw my quastion is
i need to make " Led "  works For a certain time and then close
this time i control it.
thank you
(3,976 Views)
Since you are new to the LabVIEW world, I recommend that you don't start using LIFA because it is outdated and no longer supported.  You should use LINX instead.  When go through the Firmware Wizard, you will be offered an example to try which is I think is basically what you want (If I remember correctly).
(3,542 Views)
thanks Nathan_B.
I will try LINX, thanks fo advice.
(3,542 Views)
