LabVIEW Interface for Arduino Discussions
Thermocouples? - Anyone Using Them
Is anyone here using thermocouples in their applications?  I have been using some probes that output a 0-5 volt temperature signal but will be making the change to thermocouples soon.  I am wondering if anyone has tips on what shield or what add on hardware is easiest to get running with the LIFA platform.  Has anyone done this yet?  My main concern is having enough resolution in the A to D conversion to maintain good resolution over the thermocouple range, hence the add on hardware.  Any tips?
Message 1 of 9
(10,861 Views)
Hi
I only know this cheaper solution http://www.sparkfun.com/datasheets/IC/MAX6675.pdf.
king regards
cpalha
Message 2 of 9
(5,685 Views)
I have seen this solution but never used it.  I guess the next question is if anyone has done SPI on LIFA and if it works.
Message 3 of 9
(5,685 Views)
There is also the Max31855 which has a higer measurement temperature range and a 14 bit AD converter.
<http://www.maximintegrated.com/datasheet/index.mvp/id/7273>
For a thermocouple amplifier there is the AD8495:
<http://www.analog.com/en/mems-sensors/digital-temperature-sensors/ad8495/products/product.html>
hrh1818
Message 4 of 9
(5,685 Views)
I also need to use thermocouples with my arduino and LIFA.
I've just ordered some MAX6675 anb MAX31855 ICs,
I'll post here if I manage to do something that works. (it's also my first time using SPI).
I'am interested also in getting your results Thinker_007
regards
antoine
Message 5 of 9
(5,685 Views)
Hi
I use a lot of thermocouples all days, but with other equipements.
For this do you know the lm35? Is the chepeast temperature sensor and you need to supply 5 volts and you have an output in milivolts x100 =ºC
Arduino uno has 6 analogue pins so you can connect 6 lm5 sensors.
Of course the thermocouple is quite simple to work, but it is not easy to put our boards reading it.
cpalha
Message 6 of 9
(5,685 Views)
Yes I haev been using some of these
http://labjack.com/support/ei-1022/datasheet
I believe it is based upon the LM35.  They work well but I would like a little bit better resolution than they offer.
Message 7 of 9
(5,685 Views)
I just found this :
https://decibel.ni.com/content/thread/13655?start=45&tstart=0
I've not gone through the whole thread yet, but I think it could be a great help...
cheers
Antoine
Message 8 of 9
(5,685 Views)
Have anyone VI for thermocouples and arduino ???
Message 9 of 9
(5,685 Views)
