LabVIEW Interface for Arduino Discussions
Using the "write digital port" function with Arduino Mega
I made a mistake in the firmware part of that function.  Fixed and updated above.
Message 11 of 15
(2,216 Views)
Hi Nathan,
It now works perfectly. All 8 bits are set in 40...50us at most. The delay between individual bits setting time is around 5us. The overall test time decreased more than 3 times (Arduino was a real bottleneck).
Thanks a lot!
Catalin
Message 12 of 15
(2,216 Views)
Thanks for the quick help but the Vi "DigitalWriteByte" only works to pin 13
Message 13 of 15
(2,216 Views)
What do you mean?  "Digital Write Byte" lets you write to 8 pins at a time starting at "Start Pin".  "Digital Write Port Mega" writes to all digital pins on the Mega.
Did you upload the custom firmware?  Could you please attach your VI?
Message 14 of 15
(2,216 Views)
Thank you so much,Thank you so much,
it works i forgot to config the Digital Pins.
Message 15 of 15
(2,216 Views)
