LabVIEW Interface for Arduino Discussions
What capability would you like to see added to LIFA?
We have a poster who is looking for project ideas.  Hence now is a good time request new LIFA capability.   Lets put  his enthusian to work adding new capability to LIFA.
hrh1818
Message 1 of 14
(7,087 Views)
A quadrature encoder read VI would be useful for low count encoders like that in the Lego Mindstorms NXT motor.
Thanks!
jimmyservo
Message 2 of 14
(4,161 Views)
Mmmm . . Encoders . . That's one of the things that I've done that I haven't got around to making a generic version for the community.
Message 3 of 14
(4,161 Views)
How about having LIFA to work with Arduino Ethernet Shield ?
mffba
Message 4 of 14
(4,161 Views)
mffba
The Arduino as a client or as a server?
Message 5 of 14
(4,161 Views)
The Arduino acts as the client meanwhile LabVIEW as a host to read/write the Arduino's I/O
mffba
Message 6 of 14
(4,161 Views)
I'd like a OOP version of LIFA to allow extending the base class easily for distinct projects.
GCentral ChampionCLA
Message 7 of 14
(4,161 Views)
I'm kind of familiar with OOP but could you give an example in the context of LIFA to which you are referring?
Message 8 of 14
(4,161 Views)
A wonderful task could be the possibilities to acquire Fast Analog / continuous sampling for more than one pin (frequency 5 KHz/number of pin), a function like to "analog read port".
Message 9 of 14
(4,161 Views)
Occasionally, I add new "cases" to the LIFA code that correspond to specific things I do on a particular setup, like when I create a dedicated shield and perform a task not available with the Arduino libraries. It is easier to extend and maintain the code if I can inherit from the base class and simply add those extra methods that I need.
I know others have done it for themselves (wrapping the LIFA code in a class). I'd be happy to submit mine if this idea makes sense for others.
Message 10 of 14
(4,161 Views)
