LabVIEW Interface for Arduino Discussions
You can download a LabVIEW program on the Arduino
The Arduino is an interesting platform to develop automated projects, but you can download a program in memory or is there some arduino platform allows. if you want to work in an autonomous robot can not because the arduino is connected to the computer, thanks for your answers
(5,423 Views)
Since your question about runing LabVIEW code on the Arduino has already been answered (i.e. no) I'll tell you how I used Arduino for our robot.
With LIFA, Arduino is not really used like a traditional processor.  It turns the Arduino into a very diverse, programmable data acquisition board.
We simply used a FitPC on our robot that was connected to an Arduino.  So, it is entirely possible to do what you want with the Arduino if you get a FitPC or equivalent small PC that can run Windows and LabVIEW.  The only downside to a PC+Arduino setup is that the time delay due to serial communication is not well suited for closed loop control implemented in LabVIEW but it can be done assuming you can deal with the large time steps.
(4,089 Views)
Thank you esponse, found a good solution for your project, try to follow your suggestion
(4,089 Views)
hi all, review the document made ​​by @ tom, you can download a program made in LabVIEW on a microcontroller, arduino but I thought it was, @ tom is testing alternative, the program is basic but has new microcontroller peripherals, safe conduct more items, the ARM microcontroller http://www.ni.com/white-paper/7066/en  is recommended by National Instruments  https://forums.ni.com/t5/MECATRONICA-INDUSTRIAL/Labview-Arm-Microcontrolador-Test/td-p/3506579
video http://www.youtube.com/watch?v=WY57t0cFoic
(4,089 Views)
