LabVIEW Interface for Arduino Discussions
accelerometer for dc motor control
is there any way to generate pwm signal depending on the signal from an accelerometer?
(6,512 Views)
Yes.  Is there something that you are having issues with?
(5,581 Views)
sir i have attaced my vi below see if it is will give correct output.
iam using accelerometer adlx335.
sir do tell me what are the problems with this vi.
(5,581 Views)
I don't see any major issues with the code.  What happens when you run it?  Do you see expected voltages?  The more details you are able to give us, the better we will be able to help you.
(5,581 Views)
There is an Error.
LabVIEW: File is later than the current LabVIEW version
An error occurred loading VI 'accpwm.vi'. LabVIEW load error code 9: VI version (12.0) is newer than labVIEW version (11.0).
(5,581 Views)
hi , do you have any tutorial to generate pwm using accelerometer?
(4,291 Views)
