LabVIEW Interface for Arduino Discussions
arduino interface problem-TKD2 error
problem with interfacing arduino
while compile the LIFA_Base it showing error -
"Arduino: 1.6.6 Hourly Build 2015/09/01 03:14 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Sairam\Desktop\arduino-nightly-windows\arduino-nightly\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Error compiling.
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences."
(4,074 Views)
This happens because LIFA is old and unsupported.  You should upgrade to LINX (http://www.labviewmakerhub.com/linx).  You do not need to compile any Arduino code to use the default functions provided in LINX (when using Windows).
Regarding the errror specifically, you can search on these forums since this has been asked and answered many times.
(3,666 Views)
