LabVIEW Interface for Arduino Discussions
arduino nano + xbee y lavbiew
hi
I'm trying to make communication between arduino nano 3.0 xbee with labview through serial communication, eh loaded successfully but lifa basis at the time of communication does nothing. and uh I miss this one and arduino mega and it works fine, my question is the arduino nano works with labview?
(4,308 Views)
LIFA only works for Arduino Uno and Arduino Mega 2560.  You can create your own interface using the VISA serial communication VIs.  Or, you can try to use LINX (I'm not sure if the Nano is officially supported or not).  You can install LINX and see if the Nano has firmware available.
(3,574 Views)
and uh I managed to run the arduino nano with labview 2011 connected the usb, the problem is that to do with me xbee does not work, repeat and nano works with labview wire- because not respond wirelessly? excuse my English
(3,574 Views)
