LabVIEW Interface for Arduino Discussions
ask: which arduino boards are compatible with labview
Hi I'm looking to buy an arduino, and I was checking out the Arduino MINI, I just wanted to know if it is possible to use this board with labview
Thanks in advance
(3,996 Views)
You can probably make all Arduino boards compatible with LabVIEW depending on how much work you want to do (with serial communication using the NI VISA module; which is what LIFA uses).  If you are asking specifically about LIFA, then it is only designed to work on two current Arduino boards, the Uno and the Mega 2560.  LINX (the successory of LIFA) is designed for many more boards than LIFA.
(3,167 Views)
