LabVIEW Interface for Arduino Discussions
chronic problem of arduino and labview
HOLA TENGO UN PROBLEMA, INTENTO INSTALAR EL VI PACKAGER, PERO MARCA ERROR AL INSTALAR, QUE DEBO HACER PARA INSTALARLO?
(3,188 Views)
The LabVIEW Interface for Arduino (LIFA) is no longer supported.  If you would like to interact with an Arduino with LabVIEW, you should use LINX (http://www.labviewmakerhub.com/linx).  LINX replaced LIFA a couple years ago.
(3,062 Views)
