LabVIEW Interface for Arduino Discussions
digital+analog+xbee
Hi,I'm Massimo and I have a question:
I want mesure with arduino 2009 a digital signal,an analog signal and receive the value of misure on pc by xbee;the digital signal for the wind speed and the analog signal for solar radiance
I want receive these signals on pc for record it 24/24H
Can I do it or I change Arduino board?
(4,491 Views)
I tried alone if my Arduino 2009 can receive two signals, and I've seen that can do it, Thanks for your help;
I simulated the digital signal with push-button,but I saw that when I press the button, the digital signal very little influence the measurement of the analog signal
Please: someone can explain to me why? maybe I have to put a small resistance between the button and the pin for reading the digital signal?
the file that I have done is correct?
(4,064 Views)
