LabVIEW Interface for Arduino Discussions
interfacing hall sensor with labview
hi,
i want to use hall sensor to measure the blood pressure by placing it at the wrist(radial artery).what is the DAQ card number to interface hall sensor A3515 and A3516 with labview?
(3,977 Views)
Those sensors are simple analog output devices.  Just about any NI DAQ device that provides analog input will work.  You just need to determine the other specifications that you need in your DAQ device (resolution, number of channels, number of digital channels, etc.).
If you are not inquiring about the LabVIEW Interface for Arduino, then you will get better help by posting on the NI forums at http://forums.ni.com/
(3,424 Views)
