LabVIEW Interface for Arduino Discussions
millis()
How can i use the millis() function in labview?
(4,881 Views)
That depends on what you are trying to do with it.  Could you explain in detail what you are needing?
(4,165 Views)
I am trying to make this code to labview:
void loop()
  delay(100);
  int rpm=getRPM();
int getRPM()
  // sample for sampleTime in millisecs
  int kount=0;
  boolean kflag=LOW;
  unsigned long currentTime=0;
  unsigned long startTime=millis();
  while (currentTime<=sampleTime)
    if (digitalRead(hallPin)==HIGH)
      kflag=HIGH;
    if (digitalRead(hallPin)==LOW && kflag==HIGH)
      kount++;
      kflag=LOW;
    currentTime=millis()-startTime;
  int kount2rpm = int(60000./float(sampleTime))*kount;
  return kount2rpm;
(4,165 Views)
Something like this cannot be easily implemented with an unmodified version of LIFA.
To calculate the speed of a device (with your sensor) you would want to use a counter implemented with the Arduino interrupts.  I would recommend using this method even without LabVIEW.
So, the first step would require that you convert your algorithm to be a counter using the interrupts and then either calculating the speed on the arduino first and then send the speed value to LabVIEW with a custom LIFA function or sending the raw count data to LabVIEW with a custom LIFA function and then calculating the speed there.  The former of the two is probably the more accurate method.
(4,165 Views)
